| | oil for gpl | |
stefanudrea New Aveista
| Titolo: oil for gpl Ven Mar 30, 2012 6:43 am | |
| Hello my dear friends
i got a strange problem:i am using as usual gm dexos 2 5w30 oil at 15000 km.after gpl instalation i am changing the oil at 10-12000 km.the difference is that now the oil is black and this is not good for the engine.does someone suggest me to switch to other numbers as 10w30 or 0w30 or to keep the numbers but to change the company to mobil 1 or others?thank you very very much! | |
| Titolo: Re: oil for gpl Ven Mar 30, 2012 3:23 pm | |
| The car is no longer new. You could also change the oil after 1000 km. Would you find it always dark. Is perfectly normal. |
| Titolo: Re: oil for gpl Sab Mar 31, 2012 5:36 am | |
| so, you suggest me to change the numbers for the oil? | |
| Titolo: Re: oil for gpl Sab Mar 31, 2012 2:37 pm | |
| - stefanudrea ha scritto:
- so, you suggest me to change the numbers for the oil?
No, 5/30 is excellent. Take a look: If the summer is very hot and winter is not too cold, you can use the 10/40. |
| Titolo: Re: oil for gpl Dom Apr 01, 2012 10:52 am | |
| the summer is very hot and the winter very very cold here! | |
| Titolo: Re: oil for gpl Dom Apr 01, 2012 2:11 pm | |
| The winter is so cold? 5/30 is -30 + 35. Is okay for you. But you can try the 5/40, 30, is up to 35 ° and if the summer is so hot, maybe 40 is more appropriate. |
| Titolo: Re: oil for gpl Dom Apr 01, 2012 2:26 pm | |
| i made already order for mobil 1 5w30.i found a very very good price around 40 euro 4 liters.thanks for the advise anyway! | |
| Titolo: Re: oil for gpl Dom Apr 01, 2012 2:28 pm | |
- the summer is very hot and the winter very very cold here!
i cant find 5w40 in the list.where is it? | |
| Titolo: Re: oil for gpl Dom Apr 01, 2012 2:31 pm | |
| Have you ruled out the EGR valve but no light comes on? What improvements have you had? |
| Titolo: Re: oil for gpl Dom Apr 01, 2012 2:32 pm | |
i cant find 5w40 in the list.where is it? I don't know where... |
| Titolo: Re: oil for gpl Dom Apr 01, 2012 2:38 pm | |
| Let me know about the EGR... |
| Titolo: Re: oil for gpl Dom Apr 01, 2012 3:15 pm | |
| - Peppe Crillo ha scritto:
- Let me know about the EGR...
what do you want to know about egr? | |
| Titolo: Re: oil for gpl Dom Apr 01, 2012 3:22 pm | |
| What benefits have been eliminating the egr valve?
| Titolo: Re: oil for gpl Dom Apr 01, 2012 3:27 pm | |
| the small engine is going better, the engine is cleaner, and the evacuation faster!the gases are not burned again because thats the role of the EGR valve.this is a valve specially for engines to get from euro 3 to euro 4 or other.now, the new engines have no more egr.you can check | |
| Titolo: Re: oil for gpl Dom Apr 01, 2012 3:43 pm | |
- the small engine is going better, the engine is cleaner, and the evacuation faster!the gases are not burned again because thats the role of the EGR valve.this is a valve specially for engines to get from euro 3 to euro 4 or other.now, the new engines have no more egr.you can check
I will check it! My car is euro 5. |
| Titolo: Re: oil for gpl Dom Apr 01, 2012 3:45 pm | |
| i think that you dont have it anymore. i have euro 3! in origin suppose to be euro 2 but because of this valve became euro 3.now my engine is cleaner even if maybe the noxes are more than usual! | |
| Titolo: Re: oil for gpl Dom Apr 01, 2012 4:23 pm | |
- i think that you dont have it anymore. i have euro 3! in origin suppose to be euro 2 but because of this valve became euro 3.now my engine is cleaner even if maybe the noxes are more than usual!
But have you seen lower fuel consumption and/or better performance? There is a difference with or without the erg? Let me know, I like to know it |
| Titolo: Re: oil for gpl Lun Apr 02, 2012 2:46 pm | |
| the fuel consumption is "around the same" but i am happy to have a healthy engine and a stronger one!i have a sensation of 1.4 or 1.6 engine, not a 1.2 engine as it is now | |
| Titolo: Re: oil for gpl | |
| | | | oil for gpl | |
