 Service says "this sound is normal" ?
Murat
MessaggioTitolo: Service says "this sound is normal" ?   Mar Giu 24, 2014 10:16 am
Greetings from Turkey. I have a 2012 Chevrolet Aveo 1.3 D LS 75hp. 1 year ago when I push the clutch, go and stop, I was hearing "glupp gluppp" sound. I went to service and my turbo selenoid valve was changed in warranty. Now, the "glupp glupp" sound started again. Yesterday I went to service, they added this part to behind of the turbo selenoid valve, which is no equipped in the car's originally:
I came home yesterday and I hear this another sound, like "chlank chlank":
Today I went to service again and they said: "This is EGR valve cleaning sound and it's normal. All 1.3 CDTI cars have this sound. No problem." Is it real? I've been 20.000 kilometers with my car and I didn't hear that sound before. And it started yesterday, when they added a extra part. Sorry for my bad English. In Turkey, this car is not sold too much and nobody knows anything about this car and I want to ask you. Do you have this sound?
MessaggioTitolo: Re: Service says "this sound is normal" ?   Mar Giu 24, 2014 1:00 pm
Welcome to our forum!
I haven't Aveo Diesel, but I shared this topic on facebook to report it to the other members. I hope you will soon find a solution to your problem! Hello, Luca
pensatore
MessaggioTitolo: Re: Service says "this sound is normal" ?   Mar Giu 24, 2014 1:15 pm
I used to hear the "glupp glupp" sound when i pushed the clutch. The service moved the turbine valve away from its original position and then I never heard the sound again.
Particularly, they fasten the valve to the intake manifold.
I'm not sure your problem is the same, but i thing so. If I'm right, the EGR valve is not involved in this issue.
Look at this topic:
http://aveo.forumattivo.com/t3476-rumore-con-frizione-abbassata
MessaggioTitolo: Re: Service says "this sound is normal" ?   Mar Giu 24, 2014 3:04 pm
Hi Murat, i have same engine and i watch the video. I think you have this problem
As pensatore says when we stop the car and pushed the clutch or brake it makes noise. This noise looks like a liquid bubble in a pipe. But your video i listen a different noise.
When you listen this noise?
Murat
MessaggioTitolo: Re: Service says "this sound is normal" ?   Mar Giu 24, 2014 3:41 pm
Thanks Admin Smile Thanks pensatore, if I don't misunderstand, marioilbello in that link has the same first and second problem with me. I don't know is the second problem in the video related with the tube which they inserted?
I'm in Ankara, I will go to another service in Istanbul on Thursday. I called them, they said if the EGR making sound, there is a problem and must be replaced. I trust them, when I live in Istanbul they was good.
MessaggioTitolo: Re: Service says "this sound is normal" ?   Mar Giu 24, 2014 7:32 pm
Hello Murat,
I copy you a message from a member of the facebook group "aveoclub Italia":
"ho avuto lo stesso problema con la stessa macchina e stesso motore!! è l iniettore che perde olio!! non deve assolutamente caminarci..."
Antonio has a aveo 1.3 75 hp, so it has your same car.
he also had the same problem and he says that the noise is caused by an oil leak in a fuel injector  !
He recommends that you never use the car
most likely the gasket is not positioned correctly! You can remove the cover from above the engine and and check if there are leaks oil
Murat
MessaggioTitolo: Re: Service says "this sound is normal" ?   Mer Giu 25, 2014 11:00 am
Thanks admin, is Antonio solved the problem and is he sure about I musn't use the car? I will go for Istanbul service tomorrow about 450 kilometers. The sound is not available now. I have nothing to do now if the using of car will enlarge the problem, because the service in Ankara says it's normal and it will take 5-6 minutes. That was right, after 6 minutes the car was back to normal. But Istanbul service says the sound is not normal, they must to see. I hope there will no problem for 450 kms and if there is a fuel injector problem I hope the Istanbul service can see and solve all problems before my car's ending warranty at 02/2015. In Turkey, a few another Aveo diesel owners said they also have this sound and they hear this sound only when fuel is available 1/4 of fuel tank. For real, I also have 1/4 tank of fuel now. It is a interesting detail.
Forum Aveoclub :: Tutto sulla Nuova Aveo 2011 :: [NUOVA AVEO 2011 5P] Consumi & Prestazioni :: Aveo 1.3 Diesel-
